quadracer trans oil
Old Oct 3, 2004 | 04:06 PM
92Racer's Avatar
Default quadracer trans oil
God..... you shouldn't have asked then! Go figute it out.
Old Oct 5, 2004 | 05:07 PM
emmerth's Avatar
Belray Gearsaver 80w 900ml. Almost a full quart. Do not over fill. You will blow your seals. I've seen it happen.
Old Oct 6, 2004 | 01:39 AM
Marky522's Avatar
I just asked the guy at my local dealer this, they hooked me up with the Honda HP oil, said its what they reccomend.
Mark
Old Oct 6, 2004 | 03:40 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
http://powersports.honda.com/the_goo...&TheGoodsDir=0
Old Oct 9, 2004 | 07:48 PM
  #15
Instygatr's Avatar
it says how mush right by the fill plug if i remember correctly, or at least it has one everyother motorcycle ive worked on. i did some research on oils for the tranny, and the best i came up with is amsoil. i use the stuff that says on the bottle it is designed for wet clutches, in 20-50 weight (i think). it is actually designed for use in a harlley engine (memory is failing me)
there is a oil level check plug on the water pump side. i fill mine up till it runs out, then let it drain overnight (if time) so far no problems at all.
good luck
aaron
Old Oct 12, 2004 | 07:52 PM
  #16
CTATV's Avatar
The Suzuki service manual says to run SAE 20w-40. On the side of my case, and in my service manual, it says 1000ml for the gearcase not 900. one quart is about 934ml I just put that in have been fine so-far
Halffast17
Sep 11, 2015 02:30 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
Kdgncop
Jun 17, 2015 09:37 PM
