2000 King Quad Overheating Problems
Old Oct 1, 2004 | 07:19 PM
HarleyJake's Avatar
Default 2000 King Quad Overheating Problems
I use the King Quad primarily for icefishing and never have any problems, probably because it's so cold however when I run it on the trails it overheats I know it is not due to lack of oil change or problems with the oil filter as I change oil and filter frequently It's happened a couple of times now. I am suspecting that the oil cooler may have some swamp debris in it. The Quad was used to pull a snowmobile that had broken through the ice out of a swampy area and the whole machine was full of lots of swamp goo. I will check the oil cooler to make sure that that is not the problem. If it is , it's a simple fix.
Has anyone else experienced overheating problems with their King Quad. Any ideas or suggestions if it's not the oil cooler?
Thanks in advance
HarleyJake
Old Oct 26, 2004 | 07:05 PM
Scottishquads's Avatar
As you have said check your oil cooler, and also depending apon the age of the King wither it has a Fan for cooling the engine .If so check that it is working as sticks sometimes get jammed in the blades of the fan and blow the fuse , also check the oil temp switch works for the fan.
Hope this helps.
Also if your mixture is too Lean this can cause your engine to run at a higher temperature
green giant
Jul 13, 2017 12:07 PM
wbfjim
Jun 8, 2015 06:20 PM
Scott-Leigh
Jun 6, 2015 09:10 AM
ferret3
Aug 4, 1999 08:23 PM
