Striped bolt on my Z-400. HELP!!!
Old Oct 12, 2004 | 08:58 PM
MURDR's Avatar
Default Striped bolt on my Z-400. HELP!!!
The bolt that holds my oil line on to my quad is stripped. It has a head that uses an 5mm alan wrench. By the way i just got my engine back from yoshi and this is the only thing thats holdng me up. PLeas help with some suggestions.
Old Oct 12, 2004 | 09:03 PM
99WarriorCustom's Avatar
Hello,
Depending on your wallet either go to you nearest car shop and pick up tap and die set(very good investment if your into serious ATVing) or take the bolt to your nearest shop and the will fix the threads for you
Old Oct 12, 2004 | 09:06 PM
MURDR's Avatar
Its not the threads it s the head of the bolt that is stripped. The part where you put the alan wrench is stripped
Old Oct 12, 2004 | 09:33 PM
kybabyn's Avatar
how did they manage to strip an alen one.usually those dont strip unless you use the wrong one. k well heres a few tricks i like to use a dremel and cut a slot in the head. use wd40 in the threads so it will come out easy and use a flat blade or a long peice of flat metal stick it in there and turn like a wrench. or you can get easy out from sears. the slot usually always works though
Old Oct 13, 2004 | 12:10 AM
MURDR's Avatar
My old man took the bolt out with a chizel and a hammer. Can you Believe that!!!
Old Oct 13, 2004 | 01:00 AM
warrior226's Avatar
You just got that motor back from yoshi, I'd wait and buy a new one tomorrow. I wouldn't want to mess with no oil going to a new motor!
Old Oct 13, 2004 | 03:51 AM
MURDR's Avatar
Already have a new bolt in.
Old Oct 14, 2004 | 07:40 PM
Hey
Good thing... Next time you might be able to use a very very thin cutting disk, cut the width of the head and use a flat head screwdriver
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
johnny1982
Sep 13, 2015 07:41 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
