The BIGGEST Zilla
Old Nov 18, 2004 | 07:41 PM
  #91
QuadLT500Racer's Avatar
Default The BIGGEST Zilla
i didnt see wannaracelt500 in here?
Old Nov 18, 2004 | 08:03 PM
  #92
yfz470racer's Avatar
i wonder where wannaracelt500 is he must of felt bad bout not getting caught
Old Nov 18, 2004 | 09:53 PM
  #93
ZukZilla550's Avatar
4.53's.
Old Nov 18, 2004 | 11:29 PM
  #94
lt500abuser's Avatar
i'm thinkin' about pullin' the engine out and put a sail on it. that will make it so much faster,he he haha.some of you punka$$'es need to learn how ride in the first place. WFO
Old Nov 19, 2004 | 09:48 AM
  #95
motox26's Avatar
Shed Knocker Rider
Harley Punk!
He got booted.
Old Nov 19, 2004 | 04:18 PM
  #96
yea i know he got booted but how will he be able to get back on
Old Nov 19, 2004 | 04:38 PM
  #97
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Booted means you don't come back, unless you get a new e-mail address and make a new screen name.
Old Nov 19, 2004 | 06:06 PM
  #98
oh i did not know that
if thats the case than im back
Old Nov 20, 2004 | 01:11 AM
  #99
Instygatr's Avatar
i heard a rumor of a big zilla coming soon also. I hear the GURU is gunna take names [img]i/expressions/face-icon-small-smile.gif[/img]
I wish him much luck and wish i had his knowledge. (i also wish i could afford the motor he is building [img]i/expressions/face-icon-small-happy.gif[/img] )
and here i am hoping to get some minor head mods done this year [img]i/expressions/face-icon-small-smile.gif[/img]
aaron
Old Nov 22, 2004 | 01:32 AM
  #100
86QUADRACER's Avatar
Originally posted by: roosthrower
what kind of times does your zilla run zuk?
wannaracelt500. you are a loser and should quit digging yourself in a hole.
horsepower is a function of torque and rpm. to make it, your motor needs to spin fast and retain some decent torque or make alot of torque at a low rpm. either way, it's best for straight line racing to make torque at higher rpm cause you can take advantage of gearing.
ex. 20 ft lbs @ 10000rpm yeilds 38hp
40 ft lbs @ 5000rpm yeilds 38hp
If you could manage to pull 40 ft lbs at 10000 rpm though, horsepower would double yeilding 76 hp. If you can pull hard all the way to 10000rpm, you can hold gears alot longer than you could if your motor was done at 5000rpm. basically, shift to maximize transmission output torque.
torque is a measurement of turning force
horse power is a measurment of how much somthing can pull in a certain distance and how fast it can accelreate while doing it
there for they are inderectly related.
just cause you have peak torque is at a certain rpm doen't necessarily mean you will have peak horpower at a given rpm or that it will double accordingly with torque (peak ft/lbs at increased rpm). they do affect each other but not directly
maybe you need to freshen up on your basics there?
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
