The BIGGEST Zilla
Old Nov 17, 2004 | 11:18 PM
  #81
QuadLT500Racer's Avatar
Default The BIGGEST Zilla
im sorry u dont believe the numbers dabeech man but i do
Old Nov 18, 2004 | 12:16 AM
  #82
DaBeechMan's Avatar
maybe if you owned a dyno you would understand.
Old Nov 18, 2004 | 12:28 AM
  #83
those dam* things are never consistent from what ive seen anyway
Old Nov 18, 2004 | 09:08 AM
  #84
ZukZilla550's Avatar
They're only consistant when Shee's are dynoed or Beechman's the only one.
Old Nov 18, 2004 | 09:48 AM
  #85
motox26's Avatar
Shed Knocker Rider
Harley Punk!
O now you did it!
Old Nov 18, 2004 | 05:22 PM
  #86
OK BEECH I did some more research and it seem Mid 40's RWHP.I was told 50hp,but that's at the crank.So I'll COWBOY-UP and admit I was miss informed and wrong.Disregard the dyno remark please Beech.I gotta get mine Dynoed I guess,how much is that?
Old Nov 18, 2004 | 05:31 PM
  #87
well then mine definetly prolly has 55hp or so hp, maybe a lil less. i mean u gotta figure some yfzs get 47 with the right pipe
Old Nov 18, 2004 | 05:46 PM
  #88
motox26's Avatar
Shed Knocker Rider
Harley Punk!
lets see some pics.
Old Nov 18, 2004 | 06:26 PM
  #89
DaBeechMan's Avatar
and you thought this whole time i was just trying to be a jerk...its war now mister.
  #90
roosthrower's Avatar
what kind of times does your zilla run zuk?
wannaracelt500. you are a loser and should quit digging yourself in a hole.
horsepower is a function of torque and rpm. to make it, your motor needs to spin fast and retain some decent torque or make alot of torque at a low rpm. either way, it's best for straight line racing to make torque at higher rpm cause you can take advantage of gearing.
ex. 20 ft lbs @ 10000rpm yeilds 38hp
40 ft lbs @ 5000rpm yeilds 38hp
If you could manage to pull 40 ft lbs at 10000 rpm though, horsepower would double yeilding 76 hp. If you can pull hard all the way to 10000rpm, you can hold gears alot longer than you could if your motor was done at 5000rpm. basically, shift to maximize transmission output torque.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
