The BIGGEST Zilla
Old Nov 22, 2004 | 06:07 PM
  #101
yfz470racer's Avatar
Default The BIGGEST Zilla
if only?
Old Nov 22, 2004 | 07:38 PM
  #102
roosthrower's Avatar
Originally posted by: 86QUADRACER
Originally posted by: roosthrower
what kind of times does your zilla run zuk?
wannaracelt500. you are a loser and should quit digging yourself in a hole.
horsepower is a function of torque and rpm. to make it, your motor needs to spin fast and retain some decent torque or make alot of torque at a low rpm. either way, it's best for straight line racing to make torque at higher rpm cause you can take advantage of gearing.
ex. 20 ft lbs @ 10000rpm yeilds 38hp
40 ft lbs @ 5000rpm yeilds 38hp
If you could manage to pull 40 ft lbs at 10000 rpm though, horsepower would double yeilding 76 hp. If you can pull hard all the way to 10000rpm, you can hold gears alot longer than you could if your motor was done at 5000rpm. basically, shift to maximize transmission output torque.
torque is a measurement of turning force
horse power is a measurment of how much somthing can pull in a certain distance and how fast it can accelreate while doing it
there for they are inderectly related.
just cause you have peak torque is at a certain rpm doen't necessarily mean you will have peak horpower at a given rpm or that it will double accordingly with torque (peak ft/lbs at increased rpm). they do affect each other but not directly
maybe you need to freshen up on your basics there?
Duh. I was just using those #'s as an example. You will keeping on making power until torque signs off faster than you can gain rpm needed to make more power. How dumb do you think I am?
Cummins Driver
Sep 11, 2019 01:22 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Alex G.
Sep 19, 2015 06:34 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
DeFox500
Jul 26, 2015 06:32 PM
