LT 230 smoking problem
Old Oct 24, 2004 | 08:21 PM
need2speed's Avatar
Default LT 230 smoking problem
I have a 1985 LT 230 that smokes too much. It has tons of power but blows oil smoke out the rear- before I take it apart, does anybody know of something simple to check before I take apart the top end?
Old Oct 25, 2004 | 12:51 AM
hondabuster's Avatar
Compression.
Old Oct 25, 2004 | 01:44 AM
LT249r's Avatar
doesnt the lt230 run on mixed oil with gas....? if it does, then your oil to gas mixture it too rich, if it doesnt have mixed oil, then there is probably a problem with the oil pump.. it is pumping to much oil into the gas...
Old Oct 25, 2004 | 06:41 PM
need2speed's Avatar
My 85 LT 230 is a four stroke engine that smokes - the nicotine patch didn't work- open for suggestions-
Old Oct 25, 2004 | 07:28 PM
Vinson581's Avatar
need to get her bored, .020 over at least, and order a wiseco piston to match. or/and new valve seals.
v581
Old Oct 25, 2004 | 08:49 PM
wannaracelt500's Avatar
all ur looking at is the oil ring if ur cheap or bore it over and new piston and valves i had the same problem if u take the top end off and take the oil ring off and turn it over and that will give u a couple rides wit hardly any smoke the 230s were known to have sh!ty oil rings
Old Oct 25, 2004 | 08:53 PM
LT249r the 230 is not 2 stroke it dont use a oil pump or mix gas and oil
Old Oct 26, 2004 | 06:58 PM
need2speed's Avatar
thanks for the info on the oil ring! time to do the top end over!
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
dirt ryder
Sep 27, 2015 09:22 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
