LTZ250 Stiff Suspension
I was doing some checking on one of the machines this week and noticed how much resistence there was in the travel of the front suspension w/o the shock. I speaking with some suspensions gurus I know, one sugested to loosen the A-Arm bushings bolts and see if the resistence goes away. The bushings in the LTZ250 are a rubber type, with Ny-Lock nuts. So I loosened the bolts to where they would spin freely. Amazingly the suspension would travel effortlessly. So I snugged up each bolt until I felt resistence in the travel and then backed off a touch. I only did this to one A-Arm so far the other (3) are going to gert done today. It will be interesting what Suzuki specs the torque on the bolt ? I am going to take one of the A-Arms off to check the sleeve adn bushing diameter to see if can be replaced with either an aftermarket or something like the Z400's use. We'll see. I can post photos of the differences in travel if you would like to see them.
ZooDad
ZooDad
2004, 250, adjustment, ltz, ltz250, shock, shocks, shoks, sleev, stiff, suspendion, suspension, suzuki, travel, works
