Shaving Quadracer Head
Old Nov 14, 2004 | 09:17 PM
sparknotes97's Avatar
Default Shaving Quadracer Head
I have a '91 quadracer and was wondering if I could shave the head .20", have good clearance and still run on pump gas. Any advice would be helpful, Thanks
Old Nov 14, 2004 | 10:50 PM
mucky's Avatar
I know if you shave the head the compression ratio will be higher and you might not be able to run pump gas if its to high
talk to a good rebuilder about it before you shave it
Old Nov 14, 2004 | 11:24 PM
Marky522's Avatar
i dont think you would have any problem with .20, i took .15 and feel i could have taken it to .20, next time i have it apart i will do it. I dont know if it made a difference though cause I did it when i did a rebuild.
Mark
Old Nov 15, 2004 | 10:18 AM
Bubba297's Avatar
I only tooko mine .015 as well. If you take any more you start losing the squish area and that is not good for power. If you can have the squish area redone then go for it.
1ArmBandit
55
Oct 14, 2015 09:03 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
