not charging
Old Nov 18, 2004 | 08:24 PM
meathead1's Avatar
Default not charging
put in new batt. 13 volts, started bike increase rpm still 13volts looking on line for mag priced 360.$ help could problem be something else or does anybody know where i can get mag cheaper 1999 500 quad runner
Old Nov 19, 2004 | 07:01 PM
LT250Rodney's Avatar
Was it 13V even or 13.?V Because 13V will charge the battery. 12.6 volts is what a fully charged battery is supposed to be at. Your output may just be low. Take the surface charge off the battery before you test it, by switching on the lights for a few moments with the engine off and then retest the battery.
If its not over 13 volts then the problem lies somewhere in your charging system. And before you condem that, make sure that there are no broken wires going to the battery. That could be the reason it stopped charging in the first place. I had a similar problem on my girlfriends quad. It had a brand new battery and wouldnt start. The big power wire to the starter relay had broken. So don't condemn it yet! I hate to see a fellow riders spend that kind of ruthless money if its unnescesary.
Good luck!
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
zPuls3
Sep 12, 2015 08:54 AM
