LT250R Trans Fluid
Old Sep 5, 2000 | 09:24 PM
MaineRider's Avatar
I'm trying to help a friend fix up an 86 250R and he needs to know how much and what fluid to put in after he changes his clutches.. Local shop said 20w50 but wouldnt tell him how much.. Thanks for any help
Old Sep 6, 2000 | 08:43 AM
fish_bulb's Avatar
That oil sounds fine. It will take a quart (maybe a little more). Fill it 'till you can touch the oil with your finger (you can only put your finger in so far).
Just looked at the quad: Use the oil check screw (the Fl350 uses the finger method).
Old Sep 6, 2000 | 12:50 PM
shuttlemech's Avatar
Yes that is the right oil but if you look on the case near where you put the oil in it will give you an oil amount number measure this amount in a measureing cup and put it in.
Old Sep 6, 2000 | 07:12 PM
rbowman's Avatar
I just changed the fluid in my 86 Quad Racer. What you need is 900cc of either 20W50, or a high grade 2 stroke tranny oil. Drain the old stuff out and let it drip for about 10 minutes. Put the plug back in. look down by the water pump and you will see a screw/hex in the case between the water pump and the clutch. (its the only screw/hex plug in the center of the side case). fill up the tranny until you see oil coming out of that side plug. its much like filling a differential in a truck. when it stops oozing out the side, plug it and your good to go.
MaasaiMomma
Mar 25, 2021 11:24 AM
hueby
Nov 6, 2015 11:34 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
