Winch install on a KQ
Old Nov 30, 2004 | 10:53 AM
KegCan's Avatar
Default Winch install on a KQ
Does anyone know if the warn 3.0 will fit the same mount as the 2.5 on the kq, the mounting bolt patterm looks similar.
Old Nov 30, 2004 | 06:59 PM
Topgun1's Avatar
The wires from the solenoid are supposed to go directly to the battery. Just make sure everything is tight and they don't rub on anything. Getting the power from the outlet is fine as well. Personally, I always install a toggle switch on that lead just as extra insurance so if you do accidentally bump your winch switch, it will not run and possibly do damage to your machine. If you had your hook connected to something up front and hit the switch by accident for instance, you could end up bending what it is connected to. A simple toggle on the switch power lead helps prevent this.
The bolt pattern for the Warn 3.0 and 2.5 are the same. The mount should work although the winch will be sitting a little further to the left (when sitting on the quad) with the 3.0 than the 2.5 . Looks to be about 1 1/2" further. AP sells both with the same mount so I would guess it will work just fine. The stock plate and 2.5 actually sit offset to the right so there is room to shift left.
Old Nov 30, 2004 | 07:37 PM
RedKINGQuad's Avatar
Thanks For the info.
Old Nov 30, 2004 | 11:58 PM
MonZooki's Avatar
Just as a side note: you should always store the winch with it set to spool, it will last longer and if you hit the switch it won't bend anything! Anyway Hibrass hope you get your plate soon mine took 6 weeks!
Old Dec 1, 2004 | 02:15 AM
  #15
KegCan's Avatar
Thanks for the info, i'll get the plate from ap.
Old Dec 1, 2004 | 08:03 AM
  #16
Hibrass's Avatar
MoonZuki,
I sure hope it doesn't take that long! LOL
I'm shopping for a Kodiak for the wife, I hope the Yamaha winch plan works better than Suzuki... LOL
Thanks again Guys!
Hibrass
ReconBayou
Oct 31, 2022 05:37 PM
Johnny Mac
Aug 15, 2019 03:13 PM
2many2ride
Sep 27, 2015 04:35 AM
cboler9
Sep 24, 2015 08:35 PM
