idle with z250
Old Nov 29, 2004 | 11:23 AM
suzuki04's Avatar
Default idle with z250
I own a z250 and the idle seems a little to high. When I change into 1st gear it jumps forward. How would I lower it?
Old Nov 29, 2004 | 01:34 PM
CHEWBACCA's Avatar
theres a little black **** on the left side of the engine. Start the quad and turn the **** left or right i forget which way and youll hear it idle lower or higher. Make sure u give it a little gas every few seconds to see how high it idles. Also make sure your choke isnt on when you do this or youll mess it up
Old Nov 29, 2004 | 03:01 PM
suzuki04's Avatar
Would I need a tachometer, or can I do it by ear? Do you remember if you turn it to the right or to the left? Thanks alot!!!
Old Nov 29, 2004 | 04:13 PM
Cammer's Avatar
Right increases idle, left decreases. Do it by ear. Let it warm up good and warm. Then turn it left in half turn increments until it stalls. Then turn it a half turn right and you should be set.
Old Dec 27, 2004 | 03:51 PM
poopy's Avatar
make sure choke is turned off. that will make it idle higher.
wrencher82
Sep 30, 2015 04:27 AM
IMLN
Sep 28, 2015 03:32 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
