Frame gussets for LT230S?
Old Dec 9, 2004 | 04:55 PM
LT230Sracer's Avatar
Default Frame gussets for LT230S?
Does anyone know where I could get frame gussets and how much they would cost for a 230 Quadsport?
Old Dec 9, 2004 | 05:02 PM
Semms40oz's Avatar
your best bet is just to make them, 1/8th inch thick mild steel works well.
Old Dec 9, 2004 | 10:01 PM
Thanx Semms40oz, i contacted my local machining/quad/dirtbike shop and the guy said he could make some for me.
Old Dec 9, 2004 | 10:44 PM
Does anyone know exactly where gussets would be needed on the frame?
Old Dec 9, 2004 | 11:00 PM
Semms40oz's Avatar
depends how hard you are going to be riding it... i'm not really sure why you need gussets on a 230 in the first place, but if you have your reasons i'll be happy to help.
Old Dec 10, 2004 | 12:30 AM
I really love my 230 and I don't want to give it up for another quad, plus its a piece of atv history. I want to strengthen the frame for jumping (3-5' tall jumps).
Old Dec 10, 2004 | 12:38 AM
Semms40oz's Avatar
oh ok... only week spots is around the a-arms... i'll show you some pics of place they crack 2morrow.
Old Dec 10, 2004 | 12:51 AM
I cracked the frame tube on both sides about 4'' in front of the shock mounts and the tubes are bent down about 1/4''. I was thinking i could bend the tubes back up, weld them, then cut a larger diamater tube and weld it around the spot where it cracked to strengthen that area.
Old Dec 10, 2004 | 11:07 AM
Semms40oz's Avatar
most of the cracks i've seen happen around the lower fraim rails where the a-arms connect and near the forward upper a-arm mounts...
here is a diagram of the frame... if you could download the pic and draw in red where yours has cracked then pm me and i'll give you an email address to send it to.
frame
Old Dec 11, 2004 | 05:37 PM
MBrooks420's Avatar
A very common place for the frames to fail on 230's is on the shifter side frame upright that is under the seat. You have to pull the plastics to see where it breaks. It is on the frame section that goes from behind the motor mounts in the rear, up to the spine, that the seat and tank are on. It's just about directly under where your butt would be. I have had 3 230's crack here, and always on the chain side. Not all of them break here, as I have a 230 I am riding, and a 230s frame in the attic that are both crack free. We the 230 I am riding WAS crack free. I have beat it pu pretty badly since then, and wouldn't be surprised if it was cracked.
lonerider856
Oct 13, 2023 03:45 PM
Valder
Nov 28, 2020 07:38 AM
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Honski250r
Sep 26, 2015 09:40 PM
