Biggest Jump?
Old Dec 11, 2004 | 03:47 PM
LT230Sracer's Avatar
Default Biggest Jump?
Does anyone know the biggest jump a stock LT230S can make without damage to the frame?
Old Dec 11, 2004 | 04:59 PM
RaptorRidr660R's Avatar
depends on the landing!!!
Old Dec 11, 2004 | 05:23 PM
MBrooks420's Avatar
As mentioned above the force of the jump depends on the landing. If jumping a mound onto flat land, I'd try and keep it 4-5 foot max. If jumping onto a downhill, or a double jump you could probably push it a little further. The shocks will bottom out before you do any serious damage, so back off when you start to tax the suspension.
Old Dec 11, 2004 | 06:35 PM
is a 30 foot double with a down hill landin too much? I mean 30 feet as in the distance from the jump to the landing.
Old Dec 11, 2004 | 06:39 PM
MBrooks420's Avatar
Distance is irrelevant.
Old Dec 11, 2004 | 07:24 PM
The jump is about 3 feet high, the gap is about 30', and the landing is a little shorter. If i get up enough speed I can make the jump right?
Old Dec 11, 2004 | 08:18 PM
you should have no problem jumping that as long as you clear the landing and try to land all 4 at the same time or the backs just ahead of the fronts. Just be carefull if you are new to jumping. The quad should have no problem holding up to that if its in good shape!
Old Dec 12, 2004 | 01:12 AM
ridinredODB's Avatar
eh, just jump the quad. if the frame does break you can always weld it [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 12, 2004 | 11:44 AM
mucky's Avatar
just remember the older you get the longer it takes to heal
be careful
Hack714
Sep 26, 2015 08:11 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
black_thunder
Sep 22, 2015 07:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
