Standing Z400 On End, Leeking Gas..
Old Jan 9, 2005 | 12:23 PM
ThaChad's Avatar
Default Standing Z400 On End, Leeking Gas..
Hey all,
When i installed the new full length skid plate, and swingarm skid plate, the suzuki instructions said to stand the atv on end, also i have see people who store their atv's standing on end in the garage...
well when i did stand it on end, it started leeking gas pretty bad. I never could figure out where it was comming from, but it was like a slow solid stream of gas, not just a drip.
Is that normal? or should i be worried that there is a gas leek?
Thanks.
-ThaChad
Old Jan 9, 2005 | 12:44 PM
Aaran's Avatar
its ur overflow. nothing to worry about it is b/c ur tank was full or close to full that when it is tipped up it goes out the overflow through the lid.
Old Jan 9, 2005 | 01:05 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
Overflow from the tank?!?!?
Unless your gas cap has a leak, it is overflow through the carburetor, which is caused when the ATV is stood on end, causing the carb float to stick open which will drain the entire tank through the carb and out the overflow hose.
turn your fuel off at the tank petcock (if you can....my Vinson doesn't have a shut-off) and all you will have left is the minimal amount of gas left in the carb bowl to deal with.
Old Jan 9, 2005 | 01:17 PM
ElectricShift's Avatar
I stood my bike on end once for washing, it was up for like a minute and a half and I had oil in my air box, and gas all over the place. I never stand it up anymore.
Old Jan 9, 2005 | 01:31 PM
LTZ's Avatar
LTZ
Make sure the fuel petcock is not in the prime position. That will make fuel run into the carb all the time, not just when it's on end.
Old Jan 9, 2005 | 02:01 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Your fuel petcock is vacume activated when in the ON position. When you start the engine it turns on automatically, and off when you stop the engine........if it is working properly.
In the PRI position, it is wide open just like the ON position on any other bike (gets confusing). So, be sure your valve is in the ON position, and working properly. I have no problems whatsoever standing my bike up! It may leak a small amount at first (emptying the bowl), but nothing after that.
Old Jan 9, 2005 | 02:29 PM
LTZ's Avatar
LTZ
Recon, did you get the PM I sent you yesterday?
Old Jan 10, 2005 | 01:27 AM
NichelsonRacing87's Avatar
yeah the gas should not leak out the gas cap, it will leak out the overflow hoses on your carb, still nothing to worry bout, and like TexasRoadLawyer said it'll drain your whole tank if kept like that long enough, so make sure you shut the fuel off.
Old Jan 10, 2005 | 01:38 AM
ThaChad's Avatar
How do you shut it off?
It has "ON" "PRI" "RES"
No off.
It wasn't leeking a little bit, it kept leeking.
-ThaChad
Old Jan 10, 2005 | 01:43 AM
No Ruts, No Glory
you have the same problem I do....no way to shut the fuel "off"
