Standing Z400 On End, Leeking Gas..
Old Jan 10, 2005 | 02:00 AM
LTZ's Avatar
LTZ
Default Standing Z400 On End, Leeking Gas..
Like Recon said, it's vacuum activated. Meaning that the motor has to be running or turning over in some way for the fuel to flow. It basically has to be "sucked" from the gas tank while in the "ON" position. In the "PRI"(prime) position fuel will flow freely without anything being done at all.
Old Jan 10, 2005 | 01:44 PM
ThaChad's Avatar
Well it is always in the "ON", and it was flowing pretty freely with out the engine on.
-ThaChad
Old Jan 10, 2005 | 02:17 PM
LTZ's Avatar
LTZ
That's weird!! I've never had a problem standing mine up. If you figure it out please let us know....Good luck, hope you figure it out.
Old Jan 10, 2005 | 04:42 PM
chandler's Avatar
your float bowl is stuck thats all
you have automatic shut off and sometimes it sticks
no biggie i had the same problem too
Old Jan 11, 2005 | 12:07 AM
  #15
NichelsonRacing87's Avatar
Originally posted by: ThaChad
How do you shut it off?
It has "ON" "PRI" "RES"
No off.
It wasn't leeking a little bit, it kept leeking.
-ThaChad
that's those new machines for you...lol j/k i'd like to have a Z to play around on, but i'd miss the 2 stroke power.
The only other way i could think of shutting it off would be take the gas line off the carb and put a plug in it till you're done.
Old Jan 11, 2005 | 09:03 AM
  #16
1987LT250's Avatar
you all will probally laugh but....... where was this thread when i put my plow assembly on my 96 quadrunner xmas day? i had same 3 choices on valve i picked primary . got all done went to start wouldnt start . my airbox was full of gasssssssssssssss.lmao
Old Jan 11, 2005 | 11:02 AM
  #17
FsT4WrD's Avatar
How long did it stay flowing ? It will flow pretty good till the bowl is empty. I had to have mine stand on end for a couple weeks and once the bowl emptied out it never leaked a drop.
Old Jan 11, 2005 | 08:23 PM
  #18
1987LT250's Avatar
on primary it will flow til tanks empty or air box is full lmao
Old May 15, 2020 | 10:04 PM
  #19
Drew Lindsay's Avatar
Stumbled on this post because this just happened to me today. I guess my only question now would be do I need to change my oil or replace my air filter that was soaked in gas? My air box filled completely up after only 5 minutes standing up.
Old May 19, 2020 | 03:07 AM
  #20
Dry the air filter out by squeezing as much fuel as possible out of it, and check if the oil level has risen and if the oil smells of fuel. If it does, change it. However, standing up, there shouldn't be a way fuel gets from airbox to engine. When on the ground, it can run through the breather pipe into the engine.
