Z400 coolant problem...
Old Jan 12, 2005 | 12:09 AM
KFXCarnage's Avatar
Default Z400 coolant problem...
articblue80 you saying its bogging?Is the choke fully disengaged?
Yes its cool to use car antifreeze.Thats what I have always used.
Remember you have to dilute the antifreeze before you put it in your radiator.
I usualy go half and half,half water and half antifreeze.Also don't use tap water as this will cause unnessary corrosion over time,use distiled water,can be found at any Wal-Mart. [img]i/expressions/face-icon-small-wink.gif[/img]I use my ratio rite to mix mine in.
Old Jan 12, 2005 | 08:31 AM
articblue80's Avatar
yeah, which switch is it? there is two? lol. Thanks guys!
Old Jan 12, 2005 | 09:22 PM
droz's Avatar
n e one?
Old Jan 13, 2005 | 06:44 PM
wheresdedunes's Avatar
It should be the one with heavier wires. One is a sensor (low power) and the other is a thermal-switch. You can also use a volt-meter and test which one gets power (12 volts) when the ignition is on. If you are losing coolant, you might want to check the oil and be sure it doesn't have water in it. If it's OK then you can replace the switch and coolant. Be sure to flush the system, mix the right ratio and use distilled water.
Old Jan 14, 2005 | 06:53 PM
  #15
droz's Avatar
thanks
got the switch replaced and everything seems fine
oil was good but i changed it
put new anti freeze in the system and took it for a spin and the fan comes on now
Old Jan 15, 2005 | 03:10 AM
  #16
Polaris500HO4x4's Avatar
about your coolant... u need a 50/50 mix you can get it from your suzuki dealer already pre-mixed for ya
Old Jan 15, 2005 | 05:35 PM
  #17
droz's Avatar
yea i put pre mix in from the cycle shop
1ArmBandit
55
Oct 14, 2015 09:03 PM
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
