Planeing a zilla head
Old Jan 16, 2005 | 04:54 PM
emeraldisleatv's Avatar
Default Planeing a zilla head
Is it a good or bad idea? will i experience much power gains? How much should I get planed? When finished the bike will not be bored it will have carbon tech reeds and some sort of race air filter. also will it make the bike hard to start? Thanks for any help.
Old Jan 16, 2005 | 10:13 PM
ZillaRider02's Avatar
Shaving the head will increase compression, which will increase power. Yes, the bike will be "harder" to start. I personally would either leave the head stock or install a Cool Head. Your other option is to send the head to a performance for rechambering, etc. Is your cylinder ported? Do you have an aftermarket pipe? If not, more compression really isn't necessary.
Old Jan 16, 2005 | 11:16 PM
NichelsonRacing87's Avatar
you will get more compression, and if you get it done right, so it's flat, it'll be a little harder to blow head gaskets, i wouldn't get too much taken off, just enough to get the whole surface cleaned up, also i would get the top of the cylinder jug done too, i'm sleeving my LT250R and when i sleeve it i'm also going to be this to it too.
Old Jan 17, 2005 | 02:37 AM
One of the best ways to prevent blowing head gaskets is to have the head O-Ringed. Another thing, the Zilla had a problem from the start with predetonation which caused many of its problems. If your not building a race only machine, keep the compression as low as possible to make it live longer.
Old Jan 17, 2005 | 04:29 PM
My zilla is not ported ut it does have a dg pipe. It is not a race only bike its kinda an all rounder. About cool heads some guy told me you must rebuild the engine often with a cool head. Btw when i say harder to start i don't mean harder to kick just will it be more unreliable
Old Jan 17, 2005 | 07:03 PM
A Cool Head won't cause you to have to rebuild more often. Buy one with a close to stock dome in it. Otherwise, I would send the stock head in for rechambering and the O-Ring mod. More compression won't make it "harder" to start, but it will be harder to kick. A well tuned 2-Stroke (Carb dialed in, Good Reeds, decent compression) should always start fairly easily(2-3 kicks).
Old Jan 17, 2005 | 07:18 PM
LT80's Avatar
LT80 Expert
Cool head making you rebuild more/more comp making it hard to start.....
It amazes me the misinformation ppl will pass on.[img]i/expressions/face-icon-small-shocked.gif[/img]
I bet your glad you asked in here.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 17, 2005 | 09:50 PM
mine always starts with 2-3 kicks even when it's cold.
Old Jan 17, 2005 | 10:56 PM
Evilution's Avatar
hey how do you like your dg pipe ? loudness, range of power, sound...
Old Jan 18, 2005 | 11:02 AM
Duneaddict's Avatar
USE THE SEARCH FUNCTION!!!!! This topic has been kicked around before. There's a ton of valuable info here, just look for it.
Coolheads are over-rated... and over-priced IMHO
