Need help on a lt250
Old Jan 21, 2005 | 01:16 AM
99tjrockcrawler's Avatar
Default Need help on a lt250
Hi,
My buddy has a lt250 year(somewhere in the 80's I believe). The engine is different than any I have worked on. He is doing a top end and has a few questions. First, and I know this sounds dumb but, How do you drain the oil out of the crankcase? He pulled the oil plug and the crank case did not drain??? Does this quad really only take 700 ml of oil? Question of my own is there is a sight glass on the right side of the engine but it is not an oil level sight glass. What is it? and how do you check your oil level?
Thanks for any help.
Old Jan 21, 2005 | 08:05 AM
1987LT250's Avatar
that window on right side is a powervalve sight glass as you rev motor u will see that little arm move showing you its working. and be sure to disconnect the powervalve arm before lifting the head off or u risk damaging the plastic clips that hold it. and that bike must be epmty if u pulled the plug on bottom as there is no soight glass for oil only the ml specs on case. hope this helps
Old Jan 21, 2005 | 08:46 PM
Semms40oz's Avatar
also, his motor is an 87-92, 87 if there are 5 bolts holding the reed cage on and 88-92 if there are 6 bolts.... this is important since the piston is different for the 87's.
Old Jan 21, 2005 | 09:44 PM
thanks for the help. one more question.................. my buddy drained the oil thru the drain plug in the bottom of engine, but crank case is still full of oil. Is there a separate drain or is the oil we're seeing stuck in a pocket and we have to shake the quad to get it out. The reason this is a concern is because antifreeze spilled into the crank case so we need to flush the entire system, but w/the drain plug out there is still oil visible in the crank case. Why won't it drain out?
Old Jan 21, 2005 | 09:51 PM
1987LT250's Avatar
run couple quarts of gearsaver or something through it im sure u will get the anifreeze out . if plugs out ther cant be too much oil in there. and be sure to listen to semms on the year, u will need to know, or it will create a problem.
Old Jan 21, 2005 | 10:22 PM
NichelsonRacing87's Avatar
you are hardly ever going to get all of the oil out of the case, getting most of it out should be good enough, i say this because i cracked the case on my Honda 250R in 2 places at the same time causing most of the oil to drain out, then i pulled the oil plug out and drained what was left that i could get cause i had to split the case to fix my transmission cause of a broken gear, and when i split the cases there was still oil in it, all i can say is try standing the quad on end or tipping it on either side and see if that works, and yeah the little glass window is the Powervalve window to see if it's working like 1987LT250 said, and these are only on the 87-92 LT motors
like Semms40oz stated. 700 ml is alot for a quad engine, just think of a 1/5 of whiskey, it's 750ml and that's 50 ml over
good luck
Old Jan 22, 2005 | 02:58 PM
LT2Fiddy's Avatar
well im sure it is a 250R...but really someone shoulda checked to make sure it wasnt the 4 stroke LT250 instead of the 2 stroke...my old 230 had a little check glass for the oil too...
Old Jan 23, 2005 | 10:22 AM
1987LT250's Avatar
the fourstroker 250 has sight glass on its clear back by the back tire in crappy place. towards bottom of trans.
THEXOTIC1
Jan 7, 2001 03:05 AM
Zuki250r
Apr 19, 2000 02:27 PM
Mxracer98
Apr 14, 2000 05:09 PM
