Need help asap! Did I screw up??
Old Jan 23, 2005 | 05:01 PM
DirtDivaMom's Avatar
Default Need help asap! Did I screw up??
I am doing an oil change on my 04 Z400. Looking at the bike from the front underneath there are 2 holes in my skid plate.
I emptied the one further back and stuff that looks like oil came out, then I realized it is the hole in the front that is the oil drain! What did I drain and how do I put it back??
Thanks for your help!!!!
Old Jan 23, 2005 | 06:17 PM
kawzukicatguy's Avatar
I did the same thing on my 1rst oil change. I had to do it in the unloading area at the badlands after hydro locking my engine. I unskrewed the same bolt 1rst and thought [img]i/expressions/face-icon-small-confused.gif[/img] then realized the plug under the oil tank. Now I always drain both at every oil change. I guess its so you can drain that little bit of oil remaining in the crankcase since the oil tank plug doesn't drain that portion. [img]i/expressions/face-icon-small-cool.gif[/img]
Old Jan 23, 2005 | 06:37 PM
Why doesn't it say anything in the book? So you are saying I am ok?
Old Jan 23, 2005 | 06:53 PM
Yes your OK I have changed the oil 3 times like this and drained the same small amount from the engine plug each time. I think that is the plug with a built in magnet to catch metal shaving from normal engine wear. I don't know about the book. Never read it.
Old Jan 23, 2005 | 09:00 PM
Ok, done and it started up ok. Hope I didn't mess up the starter since I thought that was the oil filter!
Thanks for all the help!
Old Jan 23, 2005 | 10:45 PM
LTZ's Avatar
LTZ
When you change the oil you are supposed to drain both, otherwise you aren't removing all the old oil.........
Old Jan 23, 2005 | 11:50 PM
mucky's Avatar
drain both, thats why its called a dry sump, it keeps a little amount of oil in the case and dont forget the filter
Old Jan 24, 2005 | 12:06 AM
alwaysAz400rider's Avatar
my manual said to drain both.........i think. Doesnt matter though cuz i do anyway
Old Jan 24, 2005 | 12:42 AM
wheelinforlife's Avatar
Yeah on the ex it is the same drian both for clean oil change.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
