Suzuki z400 frame cracking on 2003
Old Feb 11, 2005 | 10:40 AM
LTZ's Avatar
LTZ
Default Suzuki z400 frame cracking on 2003
Reweld it and put on a gusset kit at the same time if you're worried about it. My Z has seen some pretty hard desert riding as well and not one problem yet, but I also changed my suspension soon after buying it....
Old Feb 11, 2005 | 10:00 PM
cNrBLASTER's Avatar
yes but i am wondering if my dad can just weld it with his welder
titanium4rider
Old Feb 12, 2005 | 09:45 AM
MBrooks420's Avatar
Just welding it won't likely strengthen the area up enough that it won't flex. If you dad has a welder he should be able to fabricate a gusset. A gusset is just a strengthening plate welded to make the area more rigid. Better shocks also help. If the paint is cracking, you are overtaxing the front. Either don't ride as hard, or get the frame beefed up.After fixing, I'd respray the gussetted area so you can occasionally check for new cracks in the paint. Don't use rattle can crap, get some good auto grade paint.
Old Feb 27, 2005 | 09:03 PM
titanium4rider's Avatar
yes but what is a gusset kit?
Old Feb 27, 2005 | 10:49 PM
  #15
KFX400dude's Avatar
i had my frame crack all the way through. my dad just welded mine up and put 1/8 inch steel plate on the inside of the frame at the bend by the shock mounts. that has seemed to stop the cracking.
'04 kfx400
lonestar axle
razr's on baja wheels
Valder
Nov 28, 2020 07:38 AM
Steeldon
Sep 9, 2015 09:38 AM
Jason Campbell
Sep 7, 2015 02:25 PM
Slagpolaris
Sep 5, 2015 09:41 PM
Sep 1, 2015 11:59 PM
