z 400 gas shut off
Old Feb 14, 2005 | 02:29 PM
comop650's Avatar
Default z 400 gas shut off
does the gas valve have a off or just pri. on and resrve and if not what do you turn to for trailing just bought atv for daughter got rid of hard stating 400ex life is good
Old Feb 14, 2005 | 03:06 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Just leave it on the "ON" position all the time unless it has been sitting for a while, then use "PRI" but be sure to turn it back over to the ON position.
There is no OFF position since it is vacuum fed. It confused me for a while to when I got it.
Old Feb 14, 2005 | 05:06 PM
witti's Avatar
On is just like an off position on another quad as long as its not running.
Old Feb 14, 2005 | 05:17 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
it is a vacuum operated petcock
when the engine is running,,,it applies vacuum(via a hose to the back of the petcock) to a diaphram that opens and lets fuel run thru
pri (prime) will allow it to run free when it is not running
Old Feb 15, 2005 | 01:21 PM
comop650's Avatar
THANKS for all the help I know I'll be needing more help sometime
lonerider856
Oct 13, 2023 03:45 PM
Customer Service #1
May 15, 2020 08:46 AM
mrtidy
Feb 3, 2016 05:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
Matt123
Sep 29, 2015 01:29 AM
