piston for ZILLA
I need to get a new piston for my 1987 zilla. I was thinking of a weisco pro lite. My cylinder is a 1mm over bore (how do you say this in 0.0???). Also is their any other piston you would recommend or where on the web can I get pistons. Thanks for the help guys
I would go with a wiseco allways trusted. Usually want the shop that bored or honed the cylinder to match it up for ya unless you confident on your skills. You can get them about anywhere I buy most of my stuff from rockymountian atv out of utah.
88 lt 500r
91 lt 250r
03 hp 300 GG
88 lt 500r
91 lt 250r
03 hp 300 GG
here is a web site the might come in handy for you.[img]i/expressions/face-icon-small-happy.gif[/img] http://www.pistons-online.com/
I got the cylinder honed I don't need to get it bored it is just the piston was worn and had scratches. I figured out that the piston in it is a weisco pro-lite. Also I found out that it is written as 0.040inch overbore and rocky mountain hasthis piston, rings, clips and wrist pin for $84.99, which I don't think is bad. I've e-mailed both rocky mountain and pistons-online for shipping and any info.
Originally posted by: truckracer
You still need to have the clearance checked. Machine shops match the piston to the cylinder to ensure the proper clearances, forged pistons require more than cast pistons. If the clearance is too tight the engine will sieze, too loose and it will wear out very quicky or break the rings and damage the cylinder.
Originally posted by: emeraldisleatvI got the cylinder honed I don't need to get it bored it is just the piston was worn and had scratches. I figured out that the piston in it is a weisco pro-lite. Also I found out that it is written as 0.040inch overbore and rocky mountain hasthis piston, rings, clips and wrist pin for $84.99, which I don't think is bad. I've e-mailed both rocky mountain and pistons-online for shipping and any info.
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
