Z250 hard to start
Old Feb 27, 2005 | 09:51 PM
DeShawn's Avatar
Default Z250 hard to start
Hello,
Recently I was going to take out my Z250 but it wouldn't start. The temp was cold but i had the gas on prime and full choke, it would start, then die after about five seconds. This is a 2004 z250, all stock, i recently changed the oil and cleaned the filter, sometime around august, and probably not ten hours on it since. any help would be appreciated. thanks
Old Feb 27, 2005 | 10:06 PM
86LT250RFatty's Avatar
turn your gas on or add gas! my friends rappy did that, started then died, then it wouldent start at all. he eneded up not having any gas, or, drain your float bowl, see if theirs any gas in it, or check your spark pluG
Old Feb 28, 2005 | 05:36 PM
z250freak's Avatar
That happend to me too. I tried turning up the idle just a little bit and now it will start up instantly.
Old Feb 28, 2005 | 05:48 PM
GTFZ250's Avatar
There are a couple things I have noticed about the Z250s and their starting problems. If it wont start at all fill the tank completely. Mine did that once, started then died and refused to start again. It was just because it was out of gas (well I could see gas in there but I geuss it was just low enough) Turned it to reserve and she fired right up. Try choke half way also and if she wont stay idleing after that then turn up your idle so that she idles soundly and does not try to stall on you. Anything below 20 degrees and she will give you some trouble starting. If this still doesnt work then you may have a cogged jet in the carb or your choke cable could be out of adjustment. And remember that if you change the idle screw set it back to normal once she is fully warmed up.
Hope this helps...
Old Feb 28, 2005 | 06:52 PM
DeShawn's Avatar
Thanks for the replys
GTFZ250- so right after the quad is warmed up i can put the idle screw back to its normal position, when i do this do i shut the quad off? Also, dumb question, but where is the idle screw, thanks.
Old Feb 28, 2005 | 07:33 PM
z250freak's Avatar
It located on or by the carb on the left side I think. Its a little black ***.
Old Feb 28, 2005 | 08:17 PM
mahnster's Avatar
It helps to have the quad running while setting the idle.
Old Feb 28, 2005 | 09:00 PM
poopy's Avatar
the idle screw is a little black screw on the left side near the carb. no you dont have to turn the quad off to adjust the idle. by the way dont leave it on primer while your riding.
Old Mar 1, 2005 | 09:50 AM
BrocksZ's Avatar
Why not?
Old Mar 1, 2005 | 10:46 AM
DeShawn's Avatar
BrocksZ- I don't kno the reason why you shouldn't leave it on prime while your riding, but i know whenever you arent riding the quad and its off, keep it either in the on position or res.
