mild rebuild help needed
Old Mar 24, 2005 | 05:27 PM
88Qracer's Avatar
Default mild rebuild help needed
I have an 88 lt250, still to be done before spring is the mild rebuild.
The exaust valve is gummed up, so i Plan on pulling the head off to clean it out.
While off, possible a little clean up on the ports. No bore, no new piston, I know ill need new head gaskets , etc for re-assembly, but will i have to repeat the break in as if a complete top end rebuild?
Also, any tips on freeing up the exaust valve?
Other things,
the water pump seal, seems pretty straight forward, jus trickling coolant, so I will putll that apart as well
the output shaft seal, behind the front sproket. I replaced the seal last summer, once i swapped it, the thing was leaking worse than before i replaced it. Any tricks to that thing?
appreciate the help
Old Mar 25, 2005 | 12:27 AM
Doctorturbo's Avatar
GOT BOOST!
Carb cleaner works nice on anything that is gummed up. It will clean up nicely.
No need for any special break-in. Warm it up and have fun.
Old Mar 25, 2005 | 12:42 AM
Evilution's Avatar
There are many products out there that could clean this up.. without wrenching... Like Some additives to the fuel for internal motor cleaning. I dont know if the right thing to use in your case but I used some STP cleaner in my 400ex.. OMG WHAT A DIFFRENCE !!
just my 0.02 dude, that could save you lots of work and money
Old Mar 25, 2005 | 10:17 AM
88Qracer's Avatar
i tried carb cleaner into the exaust port, and tried working it free. I could feel some exterrmly filthy parts in there, but i was able to get some movement. I just dont think that I can get it free completely without popping the head off. If theres an easier way, Im all for it.
Old Mar 25, 2005 | 03:38 PM
Evilution's Avatar
This is what I used...
STP cleaner
Old Mar 25, 2005 | 05:31 PM
MBrooks420's Avatar
Does it run at all? If so I would heat it up fully and get some Seafoam. It is a liquid carbon remover. They sell it in most good auto stores. You SLOWLY let it get sucked into the back of the carb as you rev it just enough to keep it running. In an atv I'd try half a can. Then you shut it off and let it sit 5-10 minutes. Then restart and watch the smoke show. [img]i/expressions/face-icon-small-smile.gif[/img] They also sell it in a product called Deep Kreep that is an areosal version that is a little easier to use, but I don't think it is quite as strong. You can also run it in the gas to clean varnish for carbs, and injectors, and in the crankcase to remove sludge buildup in machines that haven't gotten regular maintence.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
jgiljr
Aug 21, 2015 06:15 AM
scaldwellk
Jun 19, 2015 05:08 PM
Dieseltrash
Jun 6, 2015 09:53 PM
