warning:05 kq oil drain plug stripped
Old Mar 27, 2005 | 09:26 PM
prj5757's Avatar
Default warning:05 kq oil drain plug stripped
i changed my oil today and stripped the drain plug hole. i put the bolt in finger tight then took the ratchet in the palm of my hand to snug down before torquing. well it never snugged, so i removed the bolt and there were all the threads stuck to the bolt and the hole looked just like it had been reamed. the bolt is a 12mmx1.25 pitch.i am a machine repairman by trade at allison transmission div. so i do know a few things about tapping cast aluminum and to put a fine thread in a position like that is just plain nuts! there is plenty of stock so i drilled and tapped it for a standard 9/16x12. i hope that maybe the threads were cracked at the factory and that this is an isolated case but i have a bad feeling. these are new quads and i bet nobody has changed their oil more than once or twice. these threads are not going to take being retightened over and over no matter how gentle you are.good luck.
SDR-II
Sep 29, 2015 01:06 AM
Polaris5
Aug 29, 2015 09:11 PM
JohnnySplat
Aug 6, 2015 12:07 PM
momma's bike
Aug 6, 2015 09:49 AM
Shifts
Jul 3, 2015 07:59 AM
