Are you tired of the dissing of the K.Q.?...I sure am
Old Mar 31, 2005 | 04:07 PM
Topgun1's Avatar
Default Are you tired of the dissing of the K.Q.?...I sure am
On the one I saw, they replaced the entire lower end, bearings and all. I'm sure not all dealers do that though. There are shortcuts they can take such as just moving the pinion from the old case to the new one without resetting / checking the clearances. It would be a safe bet a lot of dealers don't have the skills to do that. This fix is very involved and requires a lot of skill and time to do properly, but it can be done.
All I can say is the King Quad is a very nice machine but if you go out and buy one of the effected models with this knowledge, you are crazy, especially since the updated version can be found out there if you look and are persistant. I don't call that dissing the machine, that is just stating common sence.
For the record, I was with you Pastor back in the beginning (check previous posts) till I saw the failure first hand and the reason for it. Over time, I think you will see the failures multiply quite a bit. Good thing it is a 5 year warranty. By the way, you have been buying a King Quad for several months now but still don't own one. Are you waiting for an updated model? If it is not an issue, why the delay?
Old Mar 31, 2005 | 07:20 PM
Pastor's Avatar
TopGun...since you ask...I was tidying up several other situations until I could put substational cash on the machine. Make no mistake...I am buying one of these probably next week. Why? From my investigation of the problem, the reverse problem is a low percentage of actual machines purchased. I really don't use this machine in the mud, deep water, atc. not that I won't ever use it I just don't see myself ever pushing this thing very hard in reverse. i will be on the lookout however for late model machines.
Old Apr 1, 2005 | 02:55 AM
handycap's Avatar
The reverse problem is why you can buy a 2005 KQ 700 in Neosho Missouri for $6300.00 OTD
700 Prairie for $6500.00
750BF Kaw for $6800.00
Better wait until 2006 KQ is out!
Old Apr 1, 2005 | 08:07 AM
Trailguide's Avatar
.....and the Worship of the KingQuad continues..... led around like a hook in the nose...LOL
Old Apr 1, 2005 | 11:53 PM
  #15
Fireescape109's Avatar
You know all this sounds like you all are jeaulous of the King...... You know I have read a thousand threads and not one tells me the proper number vin. that is deffective. So all I can derive from all this is someone with no knowledge of the truth!!!!!!!!!!!!!!!
Ride and enjoy the best quad this year....................................
Old Apr 2, 2005 | 12:12 AM
  #16
Topgun1's Avatar
You must be blind because I know myself, I have posted it countless times.
This number or higher: JSAAP41A_52115956
1ArmBandit
55
Oct 14, 2015 09:03 PM
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
