Lt80 transmission ?
Old Apr 3, 2005 | 03:13 AM
milkit's Avatar
Default Lt80 transmission ?
Just bought a 2002 lt80 for my son . where do you check fluid level ? drain fluid ? and fill the transmission?
Old Apr 3, 2005 | 03:30 PM
10klt250r's Avatar
on the right side of the bike on the rear swing arm you will see a spot that says 80ml. thats how mutch. and there is a small bolt on top of the swing arm near the rear. its about a 12mm if i remember, thats where you fill it ,very hard to get to with oil but i used a small fat serringe without the needle and put a peice of gas tube on the end. as far as the drain plug just look under the rear part of the swing arm you'll see it. thats all the machine holds to is 80ml crazy but i asked.nothing in the bottom end of the motor its all dry system. hope this helps. let me now if you need more.Ive had to do a lot to mine sofar so i should be able to help.
Old Apr 4, 2005 | 03:47 AM
milkit's Avatar
thanks so much , was looking everywhere . and searching web, is how i came across these forums
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
merryman
Sep 19, 2015 03:15 AM
