oil-88 250r expert advice needed
Old Apr 11, 2005 | 04:15 AM
superevil's Avatar
Default oil-88 250r expert advice needed
After my quads first hard ride after the break in(bout an hour and a half long ride),i drained my oil and it was really dark colored. Im not losing any coolant,and dont seem to be losing any oil either. Could losing a very small amount of coolant,like,not even enough to notice a level drop in the radiator cause this? What could cause this? btw it ran great the whole time and never overheated
Old Apr 11, 2005 | 01:42 PM
emmerth's Avatar
Was the oil new?
What type of oil?
What does it smell like?
You are not leaking any coolant or your oil would be milky looking.
Old Apr 11, 2005 | 04:16 PM
superevil's Avatar
it was havoline 10w 30. And i actually dug the bottle out of the garbage can to compare the smell of the oil in my engine to the smell of the oil left in the bottle,and they smell exactly the same,it seems like the oil just got dirty.
Old Apr 11, 2005 | 04:54 PM
emmerth's Avatar
It is a good thing that the oil smells the same. Smell can tell a lot about what is going on in the engine.
If it was fresh oil from the rebuild, it could have picked up some residue from the old oil. Also, in my experience with 2-strokes, the oil does tend to get darker quicker than with a 4 stroke.
I would change the oil and see if you have the same results. I personally like to use Gear Saver 80w in my crankcase and change it about every 10 hours of riding.
Good luck, you should be fine
Old Apr 12, 2005 | 03:29 AM
superevil's Avatar
yeah when i checked my coolant level after the ride,it was all the way up.and i didnt go through any water at all.il just keep changing the oil every ride and watch it closely
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
txkevin
Sep 21, 2015 02:02 PM
jgiljr
Aug 21, 2015 06:15 AM
