89 lt250s problem
Old Apr 12, 2005 | 05:43 PM
deepa's Avatar
Default 89 lt250s problem
I just bought a 89 250s from my academic advisor for 1500 bucks. Was it a good deal? I think so due to a nice rebuild on the motor.
My headlight is pretty dim when the QUAD (DIDNT MEAN TO HIT ANYONES GSPOT!!!) is idling or even revving, but when i pull in the clutch cable, it brightenes up for a second like it should look like, then dims right back out.
What could be my problem? I have NO IDEA how this is happeneing. Maybe the clutch cable is rubbing against the regulator or cdi unit or something? Can someone help me?
Also, even thou its a fresh rebuild, it smokes a little bit at startup. I dont think he replaced the valves, so could they be the culprit?
OH, and the fuel line discenigrated in my hand. Does anyone know where to pick up a new one?
thanks,
Mike
Old Apr 12, 2005 | 06:37 PM
ZillaPheen's Avatar
Well Mike from what you are saying it sure sounds like to me that you havent got a clue about atv's. First off an lt250r should never be called a trike and you should be banned from working or even riding it for that matter [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Apr 12, 2005 | 06:42 PM
deepa's Avatar
hahahah i didnt even realize it. I have an honda 85 200s 3 wheeler, and im in the process of restoring it, so its what came to mind instead of quad. So shoot me.
Im sorry i hit a rough spot with you because i called it a trike. I'll make sure i know what happened before i suggest you be banned from working/riding anything you own because you made a simple typo. I hope this isnt how these boards are.
Well, If anyone can help me out, that would be fantastic. If you dont like me because i like both trikes and quads, then sorry.
Thanks,
Mike
Old Apr 12, 2005 | 06:50 PM
Scooter86's Avatar
Knows Old ATV Questions!
Actually, he has a quadsport there Zilla. At least my Qracer is valveless and pretty much smokes whenever it is running! I have no idea about your headlight. A little smoke on start up might warrant looking into, but I think that is pretty common for that engine. Does it burn any oil?
Old Apr 12, 2005 | 06:55 PM
deepa's Avatar
Ive only had it since friday, and had it out for a few hours at most. I am just working on getting it in nice shape when i take it up to my girlfriend's parents 11 acres in Maine. Just a few noticable problems is the smoking and the headlight. I took care of the idling problem with a nice carb cleaning. The pilot jet was quite clogged, you couldnt even see through it.
Another thing. When i took the slide out of the carb, it was all black. I know that the last owner had the oil drain get ripped out and needed a rebuild, but why would the slide be covered in black stuff? I took fine grade emery paper and cleaned it up nice, and i want to see if itll come back. Has anyone ever seen this before?
Thanks for the replies so far,
Mike
Old Apr 13, 2005 | 11:36 PM
submakr's Avatar
Mike,
Some smoke is normal for 2 strokes. What ratio do you mix to? I run 40:1 in all my 2 stokes and have never had a problem. I use Golden Spectro. I have no idea why the slide is black. Is it black on both sides? I wouldn't use emery cloth on it. The slide has a polished finish for airflow. I am sure some carb cleaner would work. Check the condition of the air filter. You can get the fuel line at any auto parts store. I would take the cover off on the left side of the engine. Remove the flywheel (you will need a flywheel tool form Suzuki) and check the condition of the stator. Is it all rusted up?. Clean it up real good. Hopefully your light will be bright again. Get yourself a manual. It will really help you out!!
Good luck,
Trent
Old Apr 13, 2005 | 11:39 PM
submakr's Avatar
Does he have a Quadsport or a Quadracer?????
Old Apr 14, 2005 | 02:02 AM
deepa's Avatar
its a quadsport, so its a 4 stroke. I already emery'd it up, with the finest stuff i could find, and carb cleaner didnt touch it. I scrubbed it with a cloth and carb cleaner, and nothing, so i just lightly sanded the slide.
I'll have to get that flywheel puller and see whats up
Old Apr 14, 2005 | 09:55 AM
ExplicitSound's Avatar
That black coating on the slide was put there by the manufacture of the carb. It allows the slide to move easier inside the carb. I also believe it offers some kind of protection for the slide.
Old Apr 25, 2005 | 08:23 PM
DavidLT250S's Avatar
when you are driving is the headlight just dim or totally out?
