Kingquad-.VR.-Kingquad
Old Apr 26, 2005 | 12:53 AM
kingme's Avatar
Default Kingquad-.VR.-Kingquad
If its geared much lower than my arctic cats lowest gear than Id be surprized. In super low I can get up to about 10 mph pinned. Dont forget the new king has a low also. Might not be as low but its still low.
Old Apr 26, 2005 | 01:50 PM
4wheelerfred's Avatar
10mph in 5th or 1rst? cuz it will go 7 in 5th pinned and 0.5mph in first! so i think the low on the old king is lower then the new one!
Old Apr 26, 2005 | 07:20 PM
kingme's Avatar
You missunderstood me, I know the old king is much lower than the new. I meant my arctic cat will do 10 mph in 5th gear when it is pinned. If the old king will only do 7 and they are both 300's I would say the old king is indeed geared lower than my cat.
Im sure its a pulling machine, it would be an interesting test for sure.
Old Apr 27, 2005 | 12:57 PM
MonZooki's Avatar
I think you both are talking about apples...and apples...
AC never made their own engines and trannys...they bought them from Suzuki...they are the same combo that you are talking about in both old 300's.
You are only partially right on gearing...you most also include the weight and speed into your equation. hook that winch up to a 15 pound log and turn it on buddy...I'll drag it all over the state....4000 lbs of pulling power or not...
The lowest gears don't also translate into the best pulling power in a drag off...if a guy can get some speed and weight moving in a direction it changes the outcome. depending upon the traction offered buy the soil...the old king might just find itself in a skid...weight and speed pulling it around. That's not to say that it failed...it just might not be able to bully the heavier quad around that hit its sweet spot first.... In the end it would come down to the driver, the one who put the least amount of strain and most amount of power down the fastest would start a drag or slide the other might not be able to overcome...
But since no one is really trying it...I guess we won't know?
Old Apr 27, 2005 | 07:37 PM
  #15
first of all they weight the exact same dry! second the higher geared kingqaudefi would bog if you pin it!
there would be no contest it would be about even until the new kings belt dies!
Old Apr 27, 2005 | 07:56 PM
  #16
PITOU's Avatar
Tie your 300 behind and lets go, you tell me when to stop, while you are thinking you could be going 10 mph at the most in low gear , I will be pulling you at 30mph, and that will be the fastest you atv has probebly gone in reverse or foward.
Old Apr 27, 2005 | 08:20 PM
  #17
Pepete's Avatar
well, I can try something if you want
I have a vinson and my neighbor got a 99 Kingquad in good shape with Gator tires ... maybe that could give us an idea!
Old Apr 27, 2005 | 08:23 PM
  #18
PITOU's Avatar
go for it pepete
Old Apr 27, 2005 | 10:57 PM
  #19
DO it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! the king will kick your a$$! sorry about that but the vinson is no contest!
Old Apr 28, 2005 | 01:58 AM
  #20
MonZooki's Avatar
If you both want to keep the quads...be sure to do the pull in dirt...pavement will break alot of parts for both of you!
