Newer LT 250 motor in a 86 LT 250 frame ?
Old Apr 26, 2005 | 04:56 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Default Newer LT 250 motor in a 86 LT 250 frame ?
Has anybody put the newer year lt 250 motor in a 1986 frame was it a simple swap or did you have to do any fabrication's ?
Old Apr 26, 2005 | 06:31 PM
1987LT250's Avatar
simple minor fabrications. two cuts motors in weld tube in for front lower engine mount and get newer exhaust to match motor. oh yeah think i took 2 links outta chain too.
Old Apr 26, 2005 | 06:43 PM
Tpsycho's Avatar
Thanks for the information sounds easy enough.
Old Apr 26, 2005 | 10:27 PM
sblt500r's Avatar
also you would have to weld in an upper motor mount to make it like stock. i plan on putting a 90 engine in a 86 frame.
Old Apr 28, 2005 | 03:57 PM
CTATV's Avatar
i know theres some differences but out of curiosity what would be the gain to put a newer lt motor in an older lt frame?
Old Apr 28, 2005 | 09:37 PM
sblt500r's Avatar
more aftermarket parts, a regular reed valve, a six speed transmission, plus its newer than an 85 or 86.
Old Apr 28, 2005 | 10:05 PM
86LT250RFatty's Avatar
Dont forget the powervalve! Plus, the 85-86 LT's weighed like 30lbs less then the 87+.. the 85-86 weighed 293lbs [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Apr 29, 2005 | 03:46 PM
nobrakesjake's Avatar
Made that same swap. 1986 frame 90 motor....cut off the down tube from frame...weld in upper motor mount to frame. then add gussets or some type strength to frame up front....very easy swap.
Valder
Nov 28, 2020 07:38 AM
Customer Service #1
May 15, 2020 08:46 AM
fd24
Jan 16, 2019 08:59 AM
bvolks
Sep 13, 2015 12:57 PM
cornermike
Sep 10, 2015 08:30 AM
