lt250r water pump.
Old May 1, 2005 | 06:11 AM
superevil's Avatar
Default lt250r water pump.
i am leaking a small amount of oil out of my water pump weep hole,but im not leaking any coolant out. Does this just mean the oil side seal is bad? Im replacing the impeller/shaft/and seals anyways but i am curious. my impeller shaft was kind of rough right about where the oil seal meets it
Old May 1, 2005 | 11:53 AM
sblt500r's Avatar
it would be the inside oil seal. but if the shaft has a grove in it a new seal won't do anything on a messed up shaft. but if you are replacing everything it should fix it.
Old May 4, 2005 | 04:52 PM
revhardlt250r's Avatar
damn super didn't u jus rebuild ur whole motor>? seem 2 be havn alot ov problms!! and ya ur seal is shot then ..jus replaced 1 on my freinds lt same problm!!!
Old May 4, 2005 | 09:31 PM
sblt500r's Avatar
thats one of the big problems with the quadracers. those waterpumps are always going. bad design.
Customer Service #1
May 15, 2020 08:46 AM
Levi Enstad
Sep 26, 2015 08:00 AM
BYC
Sep 25, 2015 02:10 PM
Sw00p
Sep 24, 2015 02:50 PM
