QUADRACER HELP!!!
Old May 3, 2005 | 06:49 AM
superevil's Avatar
Default QUADRACER HELP!!!
does it still seem to have good compression? if it does i would check the reeds and carb again
Old May 3, 2005 | 04:18 PM
emmerth's Avatar
I would do a compression test and check the plug (color) before I pulled anything apart. Anything over 100psi should be enough to keep the quad running. If you have less than 100, that may be the problem.
If your psi is over 100, I would check the reeds. If the reeds are ok, I would use a little 2-stroke mix and poor it down into the cylinder and try to start it. If you have spark, fuel/air and compression it should at least fire. If not, let us know and we can try other things.
I would also check you crankcase oil and see what color it is. I know when I sunk a few quads, it took several oil changes before the quad would run right.
Old May 8, 2005 | 07:17 PM
Turq28's Avatar
ok...i pulled the jug today...the reeds are FINE...but...there are sum nice marks on my motor....could this make it stop running like that???? the area of the ring where the bigger mark on the piston was almost looked melted on....it did come off though after some prying....take a look at my profile i just posted pics of the cylinder and piston....also the where the connecting rod attaches to the crank...there is a lot of side to side play....is this normal????...anything you guys can tell me would be greatly appreciated...
Old May 8, 2005 | 09:51 PM
superevil's Avatar
those are scoring marks,and i believe it is caused by overheating, mine did the same thing and i could roll start it,but it wouldnt idle or rev out,and it ran like crap. i would say you need a bore/piston definitely
Old May 8, 2005 | 09:53 PM
  #15
superevil's Avatar
and yes a little side to side play is ok on the crank,but it cant have any up and down play,i would take the bottom end to someone who really knows thier stuff and have them check the rod,
Old May 8, 2005 | 09:58 PM
  #16
sam250's Avatar
Sounds like you need a top and bottom end rebuild. 210 is the stock main jet, which is definitely too lean if your running an FMF pipe. Side to side play on the connecting rod is how you check to see if you need to rebuild your crank, any at all is too much.
Old May 9, 2005 | 07:37 PM
  #17
Turq28's Avatar
so what exactly should i have to get done to this motor...and who does good work for a decent price...(my first 2 stroke:frown[img]i/expressions/face-icon-small-wink.gif[/img]...and about that play in the rod...what does that mean for me...crank rebuild????.....
Old May 9, 2005 | 07:39 PM
  #18
Turq28's Avatar
i was looking at CT racing....http://ctracing.com/services.htm.....thats there price list...but i do not know what i shud have done....
Halffast17
Sep 11, 2015 02:30 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
jfboy
Nov 8, 2000 07:06 AM
max250
Aug 8, 2000 09:58 PM
