Eiger spark plug ?
Old May 10, 2005 | 01:51 PM
Hemi4u2nv's Avatar
Default Eiger spark plug ?
Last night I decided to pull the spark plug out of one of my Eigers to see how it was running. The plug looked good, but I noticed the plug threads into the head so that the threads are actually exposed inside the combustion chamber.... like atleast 1/8" of the threads were black. Is this normal or should I look into getting shorter plug with less threads? I worry that after a while, carbon will build up on the threads and then I'll destroy the threads in the head removing it.
Old May 10, 2005 | 03:12 PM
MeYHymN's Avatar
The carbon should never build up to the extent that you'll junk the threads on the head. Well maybe if the plug has been in the bike w/ the bike sitting for a VERY LOOONG time, but it's still unlikely. If you get a shorter plug the electrode will be farther away from the combustion center so it could possibly affect your running/tuning detrimentally. Just stick w/ the style of plug in the bike, as long as you keep up on the maintenance and not do things like use alot of force tightening the spark plug, putting the plug in the motor while it's still hot, or never doing your periodic maintenance you should never have a problem.
Old May 10, 2005 | 04:38 PM
hondabuster's Avatar
Id use whatever plug is called out in the owners manual. Sometimes theres a large champher on the bottom of the threads, and this is a place for soot and carbon to go, but it shouldnt cause any problems. If you use a dab of anti seize on the spark plug threads, you shouldnt have to worry about it coming out next time.
Old May 10, 2005 | 10:33 PM
Hemi4u2nv's Avatar
Thanks for the comments guys. I'll just pull them a few times a year and check 'em out.
Old Sep 10, 2006 | 06:26 AM
Psycholic's Avatar
What color should the plug tip be if mix is RIGHT?
Old Sep 10, 2006 | 12:11 PM
Hemi4u2nv's Avatar
Here's a good site:
http://www.maxracesoftware.com/spark_plugs.htm
Old Sep 10, 2006 | 03:13 PM
Heres another site
reading plugs
And as it was writen in the articles
Mostly valid only for full-load dyno tests ,
or if engine is quickly turned-off after
finish line, and then towed back to pits,
and spark plugs removed for readings there !
If you dont do the plug chop correctly, the readings are meaningless.
Old Sep 11, 2006 | 02:17 AM
Psycholic's Avatar
Thanks guys,,,,,interesting article! Was pertaining to drags but helpful.
I guess the best way to test ATV is rev her up and shut off immediately,,,,look for dark gray or tan in upper portion of cone
Old Sep 11, 2006 | 03:35 AM
Not quite. Revving in neutral wont do a thing...the engine needs to be under load for an accurate chop.
Heres an article, and it describes how to do a plug chop reading.
plug chop how to
Old Sep 12, 2006 | 12:15 PM
Psycholic's Avatar
Thanks again,,,,,good article
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
