Jetting my Eiger
Old Jun 2, 2005 | 11:17 PM
g1387's Avatar
Default Jetting my Eiger
Thinking about jetting a 05 Suzuki 400 Eiger manual. I want a little more pull starting out. I'm not much into working on things, so is it going to be worth me paying somebody to jet my quad for me. All you guys who have jetted your quads, let me know if its made a big difference in the power.
Old Jun 3, 2005 | 07:10 AM
LimpingLizard's Avatar
You'll definitely notice the difference. As easy as it is and as little time as it takes, I wouldn't waste the money paying somebody. Save even more money by just buying a couple jets from the dealer instead of a whole kit (if I remember right they were about 3 or 4 dollars a piece instead of 50 for a kit).
Old Jun 3, 2005 | 10:04 AM
Back40's Avatar
Agree with LL. You don't even have to remove the carb to change the main jet. Just unhook the throttle cable from the carb, loosen the clambs on both ends, rotate clockwise to get at the bowl screws. Use a new phillips bit as these screws are installed pretty tight from the factory. Be mindful of the choke cable when rotating the carb. Here's a pretty good write-up with diagrams on the CVK32.CVK32
Old Jun 3, 2005 | 10:53 AM
4xZuk's Avatar
Yup-easy. The adv. of a kit, though, is the instructions, spring, and needle jet, that are included. Also keep in mind that your air/fuel adj. might need tweeked. It's the screw right in front of the main jet on the Vinsons. Mine had to be seated, then backed out 3 turns. Besides the power, I haven't had to use the choke since I re-jetted.
Old Jun 3, 2005 | 11:48 AM
g1387's Avatar
Thanks guys, think I'll go ahead and give it a shot. With it jetted and a K&N air filter I don't see much stopping it especially when I get some MudLites, it already went pretty good with those crappy stock tires.
Old Jun 3, 2005 | 11:49 AM
g1387's Avatar
Where's the cheapest place I can get this stuff online?
Old Jun 3, 2005 | 11:09 PM
4xZuk's Avatar
OK-First, check e-bay. Also check the ATV mags-in the back-pages- for ads w/ clearance items. Also, check the ad's that are on this site. PM me on this.
Old Jun 5, 2005 | 12:55 PM
rolsmojave3's Avatar
rockymountainatv.com is the best prices i think
Old Jun 5, 2005 | 10:46 PM
GSPKurt's Avatar
I am considering it myself on my Eiger. Let us know how it works for you and how you did it. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 6, 2005 | 01:13 PM
ShadowMJP's Avatar
This may be a double post sorry if it is.
I am going to do the same thing. Any reccomendations on jet sizing for riding in the Colorado Mountains?
Brand new 05 Eiger 400
Thanks
