sticking throttle
Old Jun 30, 2005 | 11:53 PM
racer21's Avatar
Default sticking throttle
I own a 88' Suzuki Quadrunner 250 4x4, and the throttle keeps sticking. ive cleaned the carburetor many times, lubbed the throttle cabel checked the throttle box on the handle bars and havent been able to find anything. the throttle only sticks when its running. ive also put seafoam in the gas and the sticking seems to get worse and worse. has anyone had this problem before?
Old Jul 1, 2005 | 12:00 AM
RedGoblin's Avatar
WD40[img]i/expressions/face-icon-small-happy.gif[/img]Just kiddin, I'm sure you're well past that....
Old Jul 1, 2005 | 12:05 AM
racer21's Avatar
yep, ive tryed everything i know of or could think of and it just keeps getting worse and worse
Old Jul 1, 2005 | 10:54 AM
MeYHymN's Avatar
Does the throttle feel soft or mushy? Or does it just stick open? I'm assuming your carb has the needle down through the top w/ the throttle return spring enclosed inside the carb. That spring may just be worn out. Once the engine is running it's creating a vacuum inside and keeping the needle pulled open. Just my $.02. You could get all redneck like and rig up some sort of external spring on the handlebars, but that's hokey and could be a life threatening situation.
Old Jul 2, 2005 | 12:20 AM
racer21's Avatar
when its not running it opens and closes nice and easy. when its running it pushes hard just a tiny bit, then from then on it sticks and you have to crack on the gas and sometimes it will let go and sometimes its a hasle to get it unstuck.
Old Jul 2, 2005 | 06:53 PM
MeYHymN's Avatar
If you look at this carb blowup. I'd say that you need to replace the spring (#2). You may have some sort of debris in there, or maybe some scoring in the carb horn that's causing it, but I doubt it.
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
