Vinson Shifting Problem
Old Jul 23, 2005 | 11:10 PM
warriormojave's Avatar
Default Vinson Shifting Problem
Just bought this-------Please help sometimes my vinson with 1120 miles will not shift into gear. It seams like the shifter is stuck. If I put it in park sometimes I have to sove a screw driver into the box through the boot and move a cable.
I dont know if it is related put then sometimes after it is out of park it will not go into gear without force. Other times it is fine.
Unrelated: How long until I should replace the belt??
Old Jul 24, 2005 | 07:13 PM
MudHunter69's Avatar
The shifter linkage cable needs to be adjusted and will solve the shifting problem. Since you bought the machine used, it would be a smart thing to change the belt unless it looks ok. I think they recommend changing it at 2500 miles to 3000 miles but I'm not sure since I have the manual Vinson.
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
