shocks for my '04 ltz
#31
Originally posted by: fritz400ex
How much are the Yoshi 450 kits with everything you need? and whats the top speed with them?
#34
Originally posted by: SuzukiRacer51
nobody answered my qeastion..can you put web cams in a stock motor with just a exhaust? And will they give me a lot mroe noticable power gain?
#36
With out a piston change and a bigger cylinder, you will get a noticable top end change, but do the cylinder, rod and balance the crank and you will need wings.That cam is not a power cam it is a top end cam. It will scream on the top end but you will need a new cdi that allows the motor to rev higher. Until you do the piston and rod...this current set-up you want will put excessive wear on your stock rod and piston but until it blows you will go pretty fast.
#38
so Italian Stallion, basicly your telling me if I want my motor to blow up faster, add the web cams and keep the stock rod and piston(thats exactly what i wnat to happen) id rather not. So I need a high-compression piston?, and an aftermarket rod? like what exactly?
#39
It has been my experience that when you try to do this type of work without the assistance of an experienced mechanic, it ends up costing you more in the long run do to dumb things that you just didn't know...
#40
Suzuki racer also you may want to invest in a sparks pipe....What a difference it made for me. Also when I do the 300 ft drags, I strip my bike down. I take off my nerfs/bumper/skid plate and only run with a half a tank. Every 10 lbs. costs you one horsepower. Changing your sprockets and running taller tires will give you more top end...I blow away cammed honda's all the time while I am running stock. Overheating your motor costs you horsepower also.
