king quad cv boot repair need help
Old Aug 17, 2005 | 01:20 PM
feysfunworld's Avatar
Default king quad cv boot repair need help
went out for a ride last night , came out this morning and a stick had gotten stuck in my right rear and both cv boots are ripped.I have the hub off . but how do you get the boot over the cv joint or does the outer cv joint come apart or what.??
Old Aug 17, 2005 | 03:43 PM
2c3's Avatar
2c3
if its like a polaris take a big rubber hammer or peice of wood and bump on the outer joint and it will fall off the shaft. you wont have to take the knuckle off the axle on the inner joint just slide the new inner joint boot on from the outer side.
Old Aug 17, 2005 | 03:44 PM
2c3's Avatar
2c3
and also just cut the boots off if there alredy torn anyway. makes the job much easier
Old Aug 17, 2005 | 06:39 PM
done got it back together same day it pulls out or rear I had to use two outer cv covers because that was all they had hope it works!!!
TLC
Jul 25, 2015 02:24 AM
Sandman2.0
Jul 21, 2015 09:03 AM
tporath
Jul 11, 2015 12:31 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
D-Hagz
Jul 4, 2015 02:19 AM
