Patch Tire?
Old Aug 21, 2005 | 10:23 PM
shugga's Avatar
Default Patch Tire?
My Ozark has a tire that goes flat due to a hole in one of the lugs. I found the hole, but I was wondering if it is normally recommended to patch a tire or is it normally recommended to be replaced? If shops normally patch them, what do they charge?
Thanks in advance.
Old Aug 21, 2005 | 11:00 PM
Vincereeder's Avatar
Default Patch Tire?
I put plugs in mine, seems to work good. Put our local dealer says to bring it in,so they can fix it. They put a Plug + patch combo from the inside, it cost 14 dollars
Old Aug 22, 2005 | 02:27 PM
redfishdaddy's Avatar
Default Patch Tire?
I use "SLIME". It works great for thorns and small punctures. I have patched a tire on my lawn tractor and it barely holds. I think its due to the non radial tire.
Old Aug 22, 2005 | 07:15 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Default Patch Tire?
A patch or plug can usually work of the hole is in the footprint area of the tire. Doesn't do as well for a hole in the sidewall. I've got slime in mine and have a small sidewall crack - it would ooze just a little slime after a ride. I put on an exterior patch, mostly to help hold the crack together. It's lasted about 600 miles so far, but it's only a matter of time.
Jaybee
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
