Which Carb Is better?
Old Aug 22, 2005 | 04:11 PM
Dante7's Avatar
Default Which Carb Is better?
Hey I have an 86 LT250 and I was wondering what carb will work better on my quad KEHIN 36mm carburator. This came off a 87 LT250 will it fit my 86 i have a motion pro twist throttle if that makes a difference. or a 38mm lectron power jet gas carb. the guy said it is an older carb but still runs good. If it makes a difference i am planning on getting the flywheel lightened and the head milled here soon.
Old Aug 22, 2005 | 04:22 PM
midnite's Avatar
I'd go with the lectron. If I remember right the lt250r loves a bigger carb.
Old Aug 22, 2005 | 06:14 PM
ChewyR's Avatar
I think I would stay with the 36 mm Kehien for an 86 as it doesn't have a powervalve so it won't have any lowend power with a 38 mm carb. This is strictly an educated guess as I don't have an 86. What kind of Kehien is it? PJ, PWK, PE. Either way you'll have to spend some time making sure the carb is jetted to match the engine.
Old Aug 22, 2005 | 06:43 PM
86LT250RFatty's Avatar
go with the 36. i put a 36 on my 86' Lt250r, and it boged down a little more in the low end, but it hits so much harder and revvs alot higher and faster... The main difference between the 86 and 87+ engines is the 87+ make more lowend, thats all the powervalve does is add lowend..
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
