hard shifting gears
Old Aug 29, 2005 | 11:04 AM
outtaluck's Avatar
Default hard shifting gears
anyone have problems shifting gears with their z250? mine seems to get stuck or very difficult to shift to 2nd gear. all of the other gears seem fine. from 1st to 2nd gear is not a smooth shift. can i fix this or will it fix itself over time?
Old Aug 30, 2005 | 02:45 AM
MeYHymN's Avatar
Depends on the cause. I'm assuming it's a semi-automatic transmission. Even if it's not, have you adjusted the clutches recently, or ever? What have you been using for oil? It's possible that the clutches are just out of adjustment, you haven't changed your oil in a long time and it's sludging up in the clutches, or you've used automotive engine oil, or possibly the wrong weight of oil.
Try changing the oil w/ some good motorcycle oil and adjust your clutches.
This is only the best case scenarios, you could have something mechanically wrong w/ the transmission, but try these things first and see if it helps.
Sorry didn't read your other post and realize this is a new bike. The shifting is tight on a new machine. Just make sure you stick to the maintenance schedule w/ oil changes and such. The clutches are oil bathed so they respond to the quality/type of oil in the bike. The shifting will loosen up, just give it time. It took 500miles and four oil changes before my shifting started to loosen up. On a new bike, it's not only the engine that has to break-in. Also, make sure your not on the throttle when you shift, not for the first 100 miles or so [img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 30, 2005 | 02:44 PM
outtaluck's Avatar
hey MeYHymN thanks for the advice. btw love your quad!!!
Firefighter400
Oct 8, 2022 06:38 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
sara durrant
Jul 6, 2015 05:32 PM
