What brand/weight of oil do you use in your ATV?
Old Sep 2, 2005 | 10:48 AM
ShadyRascal's Avatar
Default What brand/weight of oil do you use in your ATV?
I have heard car oil is fine EXCEPT don't use 10-30 because it has an additive that is bad in the bike (maybe something the clutch doesn't like).
A friend of mine knows a chemist that works for an oil company and gets the info right from him. I always used regular car oil 10-40 or 20-50 and it worked fine, then I started buying nice new 4 wheelers and through fear bought the expensive ATV oil, works the same. Think I'll go back to the car stuff.
Old Sep 2, 2005 | 10:57 AM
Back40's Avatar
15w50 Mobil 1 redcap after breakin. No problems with my auto tranny. Noticed the cooling fan doesn't come on as often after the switch from Suzuki 10w40.
Old Sep 2, 2005 | 11:02 AM
Back40's Avatar
Hemi, checked out your pics. Nice. Thought I'd suggest installing an inline fuel filter on you Eigers. There have been numerous threads on this board about trash getting into the float bowl. Enjoy!!
Old Sep 2, 2005 | 11:38 AM
Hemi4u2nv's Avatar
Thanks, yeah, I need to get a filter on them.
Both atvs have about 150 miles on them... would you consider them broken in by now? Now I'm kinda worried i put oil in them that I shouldn't have. I made sure it met the API specs the manual specified, but I didn't see if it said it was "energy conserving" on the bottle. If i didn't hate the local Suzuki dealer so much, I'd stop in there and pick up a few quarts of the suzuki oil. There's a Kawi dealer across the highway... could I get the right stuff from them?
I changed the oil at about 110miles, so I've only been running them for two outings, (~40) miles. I should probalby just drain the oil and suck it and get the suzuki stuff.
I ordered a Suzuki service manual 187rideeasy.com ($39) that I plan to use in the future. I think the valves will need to be adjusted soon.
Old Sep 2, 2005 | 11:54 AM
  #15
TheWeedman's Avatar
ive been using amsoil HP Injector Synthetic 2-Cycle Oil, imo its the best for a blaster.
Old Sep 2, 2005 | 12:13 PM
  #16
reconranger's Avatar
Red Rider
Honda, accept nothing less!
ShadyRascal- Big mistake using car oil! See this article for the reasons.----> http://www.thumperfaq.com/oil.htm <-----
Your YFZ is a screamer, and no machine is going to be harder on its oil than the YFZ and TRX 450s. You need to use the finest oil money can buy, if you want to insure the longevity of your engine! Think about it. Cars redline at what is idle for a 450. Your motor is just into the meat of the powerband at 8,000 rpm. That rpm would destroy most cars.
Ironically, the one motor where you could use "car oil" is the Honda 450R. In this motor, Honda seperates the engine oil from the transmisson oil (God bless Honda!). So, you don't have to worry about a slipping cluthch if you run a super slick JASO MB oil in the engine, but you do need to run a JASO MA oil in the transmission (my choice is Maxima MTL in the trans.). If I were to run a "car oil" in my R, it would be Redline, the same stuff I run in my trucks. http://www.racerpartswholesale.com/redtech1.htm
Old Sep 2, 2005 | 01:41 PM
  #17
garrett5462's Avatar
I use full synthetic 10w40 Amsoil Motorcycle oil in my z and pure polaris 0-w40 synthetic in the scrammy.
Red Dragons
Mar 29, 2009 12:52 PM
Iowaboy
Apr 30, 2007 05:52 AM
workaholic
Nov 22, 2005 12:27 AM
Z40005BR
Sep 26, 2005 02:53 PM
