Hard to shift gears on a z250??
Old Oct 6, 2005 | 01:17 PM
outtaluck's Avatar
Default Hard to shift gears on a z250??
I have had my z250 for about 3 months now and I find it very difficult to shift gears. At first, it was difficult to shift from 1st to 2nd. For some reason, the quad has to slow down from first in order to shift to 2nd. I could never shift from 1st to 2nd in a smooth motion. It was always a struggle. Now most of the gears I want to shift to are having the same problem and by the time I do get the gears to shift from one to the other the quad has lost it's speed. I thought the break in period was going to help solve this problem, but it has not. Also, when I use the reverse gear, it difficult to get the gear to engage. Sometimes it will engage without any problems and other times I feel as if I have to stomp on the shifter to force it to work. Does anyone else have this problem with any of your quads? If so, what did you do to remedy this? Any suggestions would help. I hate to haul it back to the dealer and be without a quad for a while.
Old Oct 6, 2005 | 05:54 PM
thorrider250's Avatar
i had that provlem on my 250 too for like the first few months , it wouldnt go into 2nd gear but i only noticed that when i was shifting wearing shoes, when i ws in my boots it wasnt hard. i didnt do anythong to mine. it just eveentualy went away.
Old Oct 7, 2005 | 01:13 AM
outtaluck's Avatar
Interersting. Now, does this happen to most of the z250's or did I just happened to get the troublemaker version? You pointed out that this only happens when you wear shoes. Again interesting, I will try putting on my motocross boots and see how well it will work for me. By the way, any suggestions about the reverse gear not engaging sometime?
Old Oct 7, 2005 | 06:13 PM
about the reverse gear. make sure you are holding the brake in a little. i sumtines have trouble gettin it into nuetral, i have to like shake it around and stuff.. i dont know anyone else w a 250 so i dunno bout it happening to all of em.
Old Oct 7, 2005 | 07:54 PM
lilvex's Avatar
I did have that problem i agree with thorrider the type of shoes, boots, w/e does make a difference. And the reverse is kinda of weird sometimes it works good sometimes i will have to stomp but it doesnt bother me. It is hard to put into neutral sometimes what works all the time is if the bike isnt going into neutral after you clciked down more then 2 times just hit the gas a bit then down shift works all the time.
Old Oct 7, 2005 | 08:04 PM
Pinkkid's Avatar
I dunno 'boout you guys, but I never use 1st gear, it is pretty much pointless. I start in 2nd and go from there and shift is easier in riding boots for sure. Hadn't had trouble with Reverse yet.
'05 LTZ250
Old Oct 7, 2005 | 08:36 PM
ElectricShift's Avatar
You should have NO problems shifting to and from any gear when the engine is running. Take it to the dealer and get the clutch adjusted, I've had 2 z250's and have experience with 3, they never had shifting problems.
If you still have any type of warranty go get it looked at.
Old Oct 8, 2005 | 01:00 AM
poopy's Avatar
yea no problems shifting here.....tho sumtimes when im tryin to find nuetral i do have to give it a lil shake or lil bit of gas.
Old Oct 8, 2005 | 10:20 PM
outtaluck's Avatar
thanks for the tips. Still have not tried my boots on the quad yet but will do before I haul it in to the dealer for adjustments. Funny thing about this quad. One day it works great with no problems and the next day problems after problems. I guess it has it's good day and bad too.
Old Oct 10, 2005 | 06:19 PM
those wre the only probs i ever had. its a pretty good lil quad.
