Hard to shift gears on a z250??
Old Oct 10, 2005 | 06:33 PM
outtaluck's Avatar
Default Hard to shift gears on a z250??
yeah, it's definitely a great little quad. I have enjoyed since I got it. I noticed other people are eyeing my quad under the garage. I assume they think it's great too. Hopefully, not too great and steal it. Yikes!!!
Old Oct 10, 2005 | 06:48 PM
ElectricShift's Avatar
I stripped my driveshaft splines out, but I rode the bike HARD for about 2 years and didn't really do much maintenence, I shifted hard, jumped high, rode sand, ect. They're fun bikes though I liked mine
Old Oct 10, 2005 | 07:01 PM
dunbarr's Avatar
Originally posted by: outtaluck
Interersting. Now, does this happen to most of the z250's or did I just happened to get the troublemaker version? You pointed out that this only happens when you wear shoes. Again interesting, I will try putting on my motocross boots and see how well it will work for me. By the way, any suggestions about the reverse gear not engaging sometime?
Af you are having troubles gettting it into reverse...try giving just a little gas so you can free the gears up, then let it idle and you should be good
Dunny
Old Oct 10, 2005 | 11:47 PM
RealAce's Avatar
when i had my z250 i had no troubles ever shifting it but getting it in neutral i found that moving it forward or back a little bit solved the problem. but i had to get rid of the quad because it didnt have enough power
Old Oct 11, 2005 | 06:18 PM
  #15
thorrider250's Avatar
yeah, its been that way for me for a while now, ive just been waitin fir the r-450 to come out then ima get that.
Old Oct 11, 2005 | 06:35 PM
  #16
wheresdedunes's Avatar
I'm not familiar with the Z250, I have a Z400 and a 250EX. I had the same problem with our 250EX when it was new. The Honda manual has a simple procedure for adjusting the clutch. There is a locknut and screw on the front side of the motor. It's probably on the side of the Z250. Check the owner's manual...it was simple to do. You may also need to put a little pressure on the shifter as you let off the gas. This make the shifting smoother on our 250EX.
Old Oct 20, 2005 | 12:49 AM
  #17
zinnger's Avatar
Try useing syinthetic oil, see if that fix's the problem. It fixed the nochy shifting on my YFZ.
Firefighter400
Oct 8, 2022 06:38 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
sara durrant
Jul 6, 2015 05:32 PM
