'99 Quadmaster Mid Throttle Problem?
Old Oct 8, 2005 | 01:31 AM
BuzzBud's Avatar
Default '99 Quadmaster Mid Throttle Problem?
I have worked on 2 & 4 Stroke engines for many years but I could use a little input on this problem.
A friend of mine brought me his Quadmaster after the local dealership couldn't fix his problem (after $988.00 later) , The ATV starts & idles fine but at mid throttle the ATV bogs. This only happens when the engine is under a load (accelerating beyond mid throttle). On a stand and in gear or neutral it revs normally at all throttle positions, but when on flat ground under the load of it 's own weight + rider it bogs @ mid throttle ( 22mph.). The fuel circuit checks out & the carb has a new diaphram/slide plus a new coil & new plug & fresh gas. The fuel screw has been adjusted properly so the only other things I suspect is a minor short (plug connector or wiring ),Timing or Magneto gap setting.
I would appreciate any viable input to this problem. Thanks , Buzz
Old Oct 8, 2005 | 11:24 AM
garrett5462's Avatar
i had about the same problem with an arctic cat 250 i had, turns out the valves were shot.
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
