LT250r Air Striker PWK Stock jetting?
LT250r carb size? 35mm or 38mm?
I Am looking for a new carb and want a KEIHIN PWK or Stryker. My engine is not modded alot (see below) I want more bottom end than top. So should i get a 35mm or 38mm?
Also With all that Will the jetting of these carbs stock be close? If not where should i start?
**SEE POST BELOW FOR NEW UPDATED QUESTION***
I don't know, but I will tell you will have to do a plug chop to make sure. For the main I like to start rich and work my way down till it revs clean, then do a plug chop to make sure.
A simple tip when jetting you'll know when you're too rich by the way the bike runs, but you may not know you're too lean until it seizes up.
