LT230 carb issues/questions..Need some help...
Old Oct 12, 2005 | 09:25 PM
wellyman's Avatar
Default LT230 carb issues/questions..Need some help...
Hello all:
I recently bought a 86 lt230G, and I've been having horrible time with it running. It was dying at idle, under load, on hills.....Well, anyway, I bought a manual, and a carb rebuild kit for it. I've dissasembled the entire carb, but I'm confused on the needle jet. My manual says that it should fall out after I remove the needle jet holder. Either I lost the needle jet before I ever saw it, or its still in there somewhere. My kit doesn't have a needle jet in it, so I don't know if the manual is wrong in saying that there is a needle jet "part", or if its integrated in the carb somehow, Or if the needle jet is stuck in there. If I can explain this right, there is "something" in the pressed brass tube, but I don't know if there's just a taper integrated in the tube or if it's actually the needle jet stuck. I've applied what I think it excessive force on this "lip" and I couldn't get any movement. I'm just stumpted and I'm not sure what to do. Does anyone know if the pressed tubing is a straight, smooth tube or if there's some bevels in it. Help me please if anyone knows. Does anyone know what model of Mikuni carb this is exactly? I'm thinking of just replacing it if I can't do anything here.
Thanks in advance
Jeff
Old Oct 18, 2005 | 01:18 PM
UGLY88's Avatar
Nothing on a carb should hav eto be forced apart. The needle should slide up and down smoothly. Check the web for Carb 101 article to get familiar with what a carb is made of and hoe it works. This will help you get your head wrapped around the subject at hand. The needle is either attached to the slide or it fits down into the slide. with a spring holding it down.
Old Oct 18, 2005 | 02:25 PM
ThrashAndCrash's Avatar
The carb should be a Mikuni VM26SS
As far as the part you are talking about..........After you screw the cap off the top of the carb....Pull the slide out (the needle is attached to that)......look down in the carb at that point you should see all aluminum ecept for a small brass piece in the exact center...That is the "needle jet" you are talking about. To remove it, you need to remove the main jet and the main jet holder then take a soft brass punch (going down through the top of the carb) and very gently tap it out. It comes out pretty easy, but I have never had one just "fall out" [img]i/expressions/face-icon-small-happy.gif[/img] Let me know if you need anything else, i'll try to help.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
